LabWindows/CVI User Group Discussions
CVI for Linux
The instruction on the CVI build for Linux is missing a lot of vital information. Is there a more detailed step by step?
Such as...
Do the instrument driver need to reside in the /usr/local/natinst/cvi2013/instr directory? the permissions to the directory need to be open.
What is the build output going to be? I assume the {project name} but is ther an extension like windows ".exe"
Server farms... some more info on sourcing the CVIRTE for linux may be needed. so as I share my code, other info and permissions will be needed before the app will run?
(7,527 Views)
Hi ASIC_LabRat,
Could you post your question on the CVI Discussion Forum as well? http://forums.ni.com/t5/LabWindows-CVI/bd-p/180
I will soon remove the "Discussions" tab from the Community so that we can consolidate all questions in one location.
Thank you for you patience.
Anna
(6,212 Views)
