LabWindows/CVI User Group Discussions
DDC_Create​File Unexpected Error. Why?
System Using CVI 8.5 on Windows XP.
I have this function that is not working on a production system (works on development system), the error message is not very descriptive.
DDC_CreateFile "An Unexpected Error occurred in the library."
This is the call: DDC_CreateFile (path, "", FILE_NAME, FILE_DESC, FILE_TITLE, FILE_AUTHOR, &file);
I have spent a lot of time trying to locate the root cause (not feeling so hot right now), appreciate any help.
Note: I have tried the "log.cws" sample in CVI, with same results.
Thanks.
(6,019 Views)
Hey skykeeper,
You also posted on the Discussion Forums: http://forums.ni.com/t5/LabWindows-CVI/DDC-CreateFile-Unexpected-Error/m-p/2141584/highlight/false#M.... The Discussion Forums is probably a better place to discuss this issue, so let's keep this issue over there.
(5,495 Views)
