Summary
The Windows 8.1 SDK upgrade came with a host of benefits to Windows developers and can be easily enabled for use with LabWindows/CVI. The upgrade provides new functions for handling processes and threads (e.g. SetProcessInformation/GetProcessInformation), an Operation Recorder to speed up repeated file accessing, and better virtual and physical memory handling.
Note: This tip will only work on machines running the Windows 8 operating system or newer
Contents
1. Enabling the Windows 8.1 SDK
2. Examples for Windows 8.1 SDK
In order to use the new features from the SDK, two defines need to be added to the CVI project:
These can be added in the Options»Build Options»Compiler Defines field.
Two examples were shipped with LabWindows/CVI 2015 that show how to use the SDK functionality:
Did you find this tip useful? Rate this document or add a comment below.
If you give this a try, share your experience! Add a comment below.
Did as requested above but got this run error, what have I missed out?
I am running 64bit Windows 7
You're using Windows 7, so it' absolutely normal you can NOT use any API
present only in newer versions of Windows.
Il 09/03/2016 10:32, Srm27 ha scritto:
NI Community <https://decibel.ni.com/content/index.jspa>
LabWindows/CVI Tip: Using the Windows 8.1 SDK
new comment by Srm27 <https://decibel.ni.com/content/people/Srm27>
View all comments on this document
<https://decibel.ni.com/content/docs/DOC-47015#comment-47973>
Hi Srm27,
carlox is right, because the entry point of the Windows DLL changed that the SDK was using, this specific tip only works with the Windows 8 operating system or newer. I should have clarified that in the description, my apologies!
TheNIDragon
