LabWindows/CVI User Group Discussions
Multiple instance of a CVI panel
Is there anyone know how to create a multiple instance of the same CVI panel so that I can use the same panel for multiple tasks?
Thank you.
(6,983 Views)
You can load the same panel calling LoadPanel(Ex) multiple times and get a separate handle each time.
You just have to keep the panel handles in separate variables and use them in the correct place as required in your application.
S. Eren BALCI
IMESTEK
(5,697 Views)
Hi to ebalci,
Many thanks to your swift reply. Do you have an example which I can follow?
Thank you
(5,697 Views)
