LabWindows/CVI
使用LABWINDOWS/CVI调用MATLAB作为后台的数据传输的问题
// HOW TO USE "MLApp_DIMLAppGetWorkspaceData
通过create activeX cnotroler...生成成的的函数中有一个MLApp_DIMLAppGetWorkspaceData,函数定义如下:
HRESULT CVIFUNC MLApp_DIMLAppGetWorkspaceData (CAObjHandle objectHandle,
ERRORINFO *errorInfo,
const char *name,
const char *workspace,
VARIANT *pdata);
其中VARIANT *pdata这个应该怎么用?这个应该是数据输出
如何控制LABWINDOWS/CVI来获取MATLAB的计算数据?下面的代码目前还存在问题,无法获取到数值
int CVICALLBACK runMCB (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
int status;
char filename[300];
char number[300];
int result = 0;
int i;
double time[256] = { 0 };
double freq[128];
double vect_r[256],vect_i[256];
double *vecReal = NULL;
double *vecImag = NULL;
size_t dim1;
size_t dim2;
static char pathname[MAX_PATHNAME_LEN], dirname[MAX_PATHNAME_LEN];
double num,num1;
static FILE *file_handle;
char *cStr = NULL;
char DA[3200];
double tmp1,tmp2;
VARIANT DATA1;
int DATA2[5];
switch (event)
case EVENT_COMMIT:
CA_VariantSetEmpty(&DATA1);
file_handle = fopen ("C:\\matlab\\matlabfiletest\\test.txt", "w+");
result = RunMatlabCommand(hMatlab,"x=1;");
result = RunMatlabCommand(hMatlab,"y=2;");
result = RunMatlabCommand(hMatlab,"z=x+y;");
MLApp_DIMLAppGetWorkspaceData (hMatlab, NULL, "z", "base", &DATA1);
fclose (file_handle);
if (result != SUCCESS)
MessagePopup ("ERROR", "Error in running MATLAB Script");
return 0;
break;
return 0;
(3,529 Views)
Hi! Mengzhuhao,
Which version of Matlab do you have?
Is there functions named "MLApp_DIMLAppGetFullMatrix(....)" and "MLApp_DIMLAppExecute(.....)" when you created the Matlab activeX automation server?  If so, they should be the functions you use to obtain the data from Matlab.
(3,494 Views)
