Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
小女子求各位大侠指教:CVI软件运行时断点为什么执行不了
秀秀
Member
03-06-2012
08:17 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
各位大侠: 我运行CVI软件的时候,发现设置断电后,程序运行到此处没有停止。好像是自从生成了MSI发布程序后,再运行我的代码时,就会弹出一个提示框,内容大概就是是否允许断点什么的,我选择后运行到断点处程序都是可以停下来的,问题是再弹出这个提示框的时候我勾选了不再提示我,那现在断点就不起作用了。所以请大侠指点一下是不是需要设置什么地方就可以了。有遇到这个问题的哥哥姐姐们多指点一下啊||谢谢了。 0.0 龍年好运|||
0
Kudos
Message
1
of 2
(2,793 Views)
Reply
Re: 小女子求各位大侠指教:CVI软件运行时断点为什么执行不了
dcl9000
Member
03-12-2012
08:29 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
請附上你的CVI文件(*.c, *.h, *.uir, *.prj)
以便我們協助你解答你的問題
0
Kudos
Message
2
of 2
(2,778 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
