LabWindows/CVI
-129 user interface library error
(3,162 Views)
Use the function GetUILErrorString. You will find this error (-129) means "This panel operation can be performed (if a top-level panel) only in the thread in which the panel was created, or (if a child panel) only in the thread in which the top-level parent panel was created."
You must be trying to do something to a panel outside the owning thread.
Best Regards,
Chris Matthews
(3,162 Views)
