LabWindows/CVI
16 bit library
I have a 16 bit library, compiled with Borland C/C++, for a data adquisition
card. I want to use it with Labwindows/CVI. Can I use it with Labwindows/CVI
4.0.1 wich have a 32 bits compiler? if i had to use a 16 bits compiler,
which version of CVI i have to use?
Thanks a lot.
(3,729 Views)
From Labwindows/CVI Programmer Reference Manual: LabWindows/CVI for windows95
and NT does not load 16-bit DLLs. If you want to do so, you must obtain
a 32-to-16-bit thunking DLL and a 32-bit DLL import library.
"Emilio J. Góngora" wrote:
>I have a 16 bit library, compiled with Borland C/C++, for a data adquisition>card.
I want to use it with Labwindows/CVI. Can I use it with Labwindows/CVI>4.0.1
wich have a 32 bits compiler? if i had to use a 16 bits compiler,>which version
of CVI i have to use?>>Thanks a lot.>>
(3,729 Views)
Thanks Fernando but the library I want to use is a static library.
"Fernando" escribió en el mensaje
news:3a6482e0@newsgroups.ni.com...
windows95
adquisition>card.
version
(3,729 Views)
The library I want to use is a static library. I know how to use a 16 bit
dynamic link library, but no a static.
"Emilio J. Góngora" escribió en el mensaje
news:3a643874@newsgroups.ni.com...
adquisition
Labwindows/CVI
> Thanks a lot.
(3,729 Views)
