LabWindows/CVI
2D matrix sorting...
Hi...
I want to sort a 2D matrix ... decreasing order ... "m_piece[1000][5]" on the first column of the matrix...
I know that there is the CVI function... HeapSort with IntCompare ... But how I make the call...
Best Regards...
Steph
(3,815 Views)
Hi Steph, I've attached some source code with two versions in... both use the HeapSort & IntCompare functions that you mentioned, but due to the organisation of your array (1000x5 as opposed to 5x1000) the HeapSort function doesn't quite work right... So the 1st version uses a temporary array to hold the data from one of the 1000 element data sets to be processed by the sort routine. The second version changes the 2D array to a 5x1000 one, and then can simply pass the pointer to the 2nd dimension as the argument to the HeapSort function.
As it stands the HeapSort sorts the array in ascending order. If you want descending order, simply switch the arguments in the IntCompare function call
Hope this helps
JB
(3,815 Views)
Hi.
I've done a little demo to show a couple of ways for this. If you send an
email to me, I'll send it off.
Triffid.
"Steph" wrote in message
news:506500000008000000A5470000-1019262487000@exchange.ni.com...
> Hi...
> Best Regards...
> Steph
(3,815 Views)
Hi.
Triffid.
> Hi...
> Best Regards...
> Steph
(3,815 Views)
