LabWindows/CVI
3D graph of plane
I have not used the 3D graph before and am working on trying to get a shape like a rectangle or something to plot and then to rotate it based on other data. Are there any tutorials or good examples for making planes in the 3d graph? Part of my problem is getting these variants figured out and setting them to the right values for the CW3DGraphLib_CWPlot3DPlot3DSurface.
(3,030 Views)
You can find examples of using the 3DGraph under ..\CVI\samples\userint\activex. The examples should help you get started.
Bilal Durrani
NI
(3,015 Views)
