LabWindows/CVI
3d graph color map help for cvi
I've plotted my data to a 3d graph using CW3DGraphLib.  The data I am most interested in is the highest 10%.  I can change the Z axis to only show this 10%, but the colors are all red.  I would like to modify the color map so it maps only the data that I set in the max and min scale.  90 to 100%.  Does anyone know how to do this?  Also, I am looking for any additional help files on the CW3DGraphLib.  When you click on the function panel it says no help file available.
(2,942 Views)
Hello Keith,
    I think the following forum will be helpful.
    http://forums.ni.com/t5/LabWindows-CVI/the-method-CW3DGraphLib-DCWGraph3DPlot3DCurve-does-not-work/t...
Daniel
(2,937 Views)
