LabWindows/CVI
Problem Description :
my compiled code runs fine on my PC, but some other people running it get
error
-5093 which means the advanced analysis library is missing. I have checked
the
CVIRTE DLLs in their system32 folder and the file versions match mine.
How can I fix this?
(3,526 Views)
if you're building your distribution, have a look at 'Drivers and Components' in the 'Edit Installer' setup (Build / Distributions / ...) and make sure that 'Analysis Support' is checked.
(3,524 Views)
Also, the analysis library is not in cvirte.dll. It's supposed to be in C:\Program Files\National Instruments\Shared\Analysis\nianlys.dll
Luis
(3,495 Views)
