LabWindows/CVI
64 bit: inconsistent plot commands
A question, may be a comment:
While PlotXY accepts various data formats, double, int, and ssize_t integers, the plotline command is limited to double. Hence, I can not use the same data set to plot a line if the data are ssize_t integers without getting compiler warnings 'Conversion from 'ssize_t' to 'double' might lose data'. Of course, the warning is correct, but why not permit plotting integers?
(Background: sometimes events are counted and evaluated (normalized, offset corrected...) Using integers preserves precision, while at large numbers double values loose significant digits. Now, plotting a line from a large data set may be useful to connect two points from the data set, indicating a baseline ...)
Any recommendations? If not, may I suggest to update the PlotLine... commands to accept 64 bit integers, too?
(3,628 Views)
The plotting functions that accept arrays (PlotX, PlotY, PlotWaveform, etc...) can accept variable data parameters because they can simply declare those arrays as void *. But functions that take scalars (PlotPoint, PlotLine, etc...) cannot accept values of variable types in a single function. They could do it by forcing you to pass a pointer to the value, instead of the value, but that would also be more cumbersome since it would require you to always use a variable. You wouldn't be able to pass a constant instead.
The warning from ssize_t to double makes sense (in 64-bit), but you can easily suppress it by casting it to a double when you pass it to PlotLine.
Luis
(3,612 Views)
Thanks, Luis.
May I then suggest to modify some analysis functions to accept both integers and doubles, e.g. Clear1D, LinEv1D etc.: now, for integer arrays, all these nice array functions cannot be used...
Wolfgang
(3,595 Views)
