LabWindows/CVI
A custom control callback raised an exception
I modified a panel title of a .uir file in Edit Panel/Panel Setting,
when I try to save the .uir file, I got this error message.
When I try to build the project, I got:
'Unrecoverable Internal Error at 001B:10226779. LabWindows/CVI will be aborted.'
I'm using CVI 8.0.0 (273) under Windows 2000. I got a CVI project that was developed by the other people under CVI 7.1.
This project includes some .uir files and .h files.
Can anyone help?
David
(3,500 Views)
I modified and saved the same .uir file under CVI 7.1 without any problem, and built it with the project.
David
(3,496 Views)
Can you try replicating the issue with CVI 8.0.1?
This is a free maintanence version for CVI 8.0 users. If you are still seeing the problem, please attach the problematic UIR to this post and I can investigate it some more.
Bilal Durrani
NI
(3,486 Views)
