LabWindows/CVI
A problem about multiple writer server of DataSocket
I'd like to bulit a item, which can be written by a local computer and many other remote
computers, in the DataSocket server local machine.
I did it like this:
(1) Run the DataSocket Server Manager,and add the data item to the list of "Predefined
Data Items" ,name it "wave"
(2) check the "Allow Multiple Writers" checkbox.
(3) then restart the DataSocket Server for this change to take effect.
After doing this,I use the sample "writer" of"\CVI\samples\datasocket\writer" to verify it.
In the local machin,I run "writer.exe" with the URL "dstp://localhost/wave", there is no
problem. but when I run "writer.exe" in another machine with the URL"dstp://localmachine's
IP/wave", I get a error message ""Error: Can't connect to the item, another writer already
exits".
I do think I have done everything,but I cann't succeed.
Can anyone help me ? Thanks.
(3,076 Views)
What's more, my Datasocket version is 4.2, and my OS is windows 2000
(3,065 Views)
I think the problem might be occuring because you might have the entry in Write Access that allows only localhost to write. Just make sure that in the Data Item "wave" that you created the Write Access is given to "everyhost". This could as well be changed by changing the setting for the "DefaultWriter".
I hope it helps,
Rajiv
(3,045 Views)
