LabWindows/CVI
A problem for CVI 7.0 installation
I just asked a question about some examples can't be run on my computer. Now, I found that the reason should be the error occurred when I installed NI-DAQ 7.3 after I installed CVI 7.0.
"The NI-DAQ CVI API 7.3 installation has failed with the following error:
You must have LabWindows/CVI 7.0 or higher to use this API."
It's weird because I have CVI 7.0 on my computer. Itried several times till now, but the problem is still there.
I use Windows 2000, and have a PCI-6110 on my computer.
Thanks!
Marlon
(3,538 Views)
See reply here:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HFORCEKWTID=122309:5&HOID=50650000000800000088FE0000&HExpertOnly=&UCATEGORY_0=_318_&UCATEGORY_S=0
(3,538 Views)
I am facing the same problem.
Where is the solution located. I tried the other forums, but it keeps pointing to this thread again.
(3,328 Views)
It looks like this is the thread that Jeff was referring to.
Luis
(3,297 Views)
