LabWindows/CVI
A strange control array error
Template code(from help document):
GetNumCtrlArrayItems(ctrlArray, &count);
   for (i=0; i<count; i++)
      SetCtrlVal(panelHandle, GetCtrlArrayItem(ctrlArray, i), i%2);
My user interface info:
I define 2 control arrays ,here are my panel and arrays
My call back code of OK button:
int CVICALLBACK Ok (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
    int i,temp_control,count;
    switch (event)
        case EVENT_COMMIT:
        GetNumCtrlArrayItems(CTRLARRAY_2, &count);
            temp_control = GetCtrlArrayItem(CTRLARRAY_2, i);
            ResetTextBox(panelHandle, temp_control, "test");
       break;
     return 0;
This is the problem:
I want to change the text in the text box, according to the define of control array ,we should call
GetNumCtrlArrayItems(CTRLARRAY, &count);and GetCtrlArrayItem(CTRLARRAY, i);
but, when I click ok button, funtion GetNumCtrlArrayItems return -4.
And, I use CTRLARRAY_2 instead of CTRLARRAY, when I click ok button, the result is like this
Who can explain this for me ?  Is this a bug of Labwindows/CVI 2013?Thank you very much .
(5,024 Views)
Accepted by topic author EastClaus
As you can read in the help, you do not use the control constant name in this function; instead, you should call GetCtrlArrayFromResourceID  to obtain the handle to use in subsequent functions on this component.
The error you are receiving correctly states Invalid handle.
(5,014 Views)
Haha, It's great!
(5,005 Views)
