LabWindows/CVI
A way to get information about colored points from a graph?
Two questions:
1. Is there a possibility to know whether a specific point is already plotted in a graph and what is the color of that specific point?
2. Is there a way to use the legend in order to show what each colored point represents (not lines, only colored points..)?
Thank you!
(5,006 Views)
1. In principle yes but it depends.. How did you plot the data? Using PlotPoint, PlotXY, did you keep the plot handles?
2. A legend belongs to one plot, so if the plot contains more than one point I would assume that this will not work. An alternative might be to use annotations.
(4,999 Views)
1. I used PlotPoint & a function "returncolor" in order to make each colored point present a different situation depend on variable 'x':
double m_abs (double x) {
if (x < 0) return -x;
return x;
int returncolor (double x) {
if (m_abs(x) <= 0.05) return VAL_GREEN;
if (m_abs(x) <= 0.15 && m_abs(x) > 0.05) return VAL_BLUE;
if (m_abs(x) <= 0.25 && m_abs(x) > 0.15) return VAL_DK_MAGENTA;
return VAL_RED;
The problem occurs when PlotPoint used twice for the exact same point with different colors so only the last colored point would remain.
I want that in this case, only the color with the maximum variable 'x': would remain..
Sם I can solve it by saving the data to 2D array.. but I thought maybe there is an option to get true or false whether a point exist on a specific location in a graph or not, and what is the color of that point.
2. Yes, I have already used annotations., but too bad there is no way to put legend for colored points..
(4,992 Views)
The only way I am aware of would be to query plot attributes, but this also requires saving an array (of plot handles).
(4,986 Views)
Thank you!
(4,977 Views)
