LabWindows/CVI
AC Low Frequency Filter
Does anyone know the necessary Labwindows/CVI syntax for setting the AC Low Frequency filter to "FAST" for the HP (Agilent) 34970A DAQ?
(3,658 Views)
Hi Insulator,
I was looking through the user manual for you instrument and it looks like the answer to your questions is on page 88 and 89.  The link to the manual is:
Basically, you will just use a VISA write and VISA read with the commands from the manual.  Use the commands they give you for Remote Interface Operation.
For your application, you will use the "ROUT:CHAN:DELAY" function.
Scott G.
AE Specialist
(3,605 Views)
Thanks Scott.
(3,185 Views)
