LabWindows/CVI
About dotnet/RegEx example
Dear all:
       When I excute example samples\dotnet\RegEx, the err code is -6597, and err description is "Couldn't get CVI .Net error description. A .NET Framework version 1.1 or higher, or the CVI .NET library may not be installed on your system."
       But I have Installed .NET Framework 2.0 and CVI .NET library is also available. And i also tried .NET Framework 2.0, it also the same error. Can anyone help me to excute this example?
       Thanks!
(3,955 Views)
Did you install the .NET Framework after installing LabWindows/CVI? If so, then you must reinstall LabWindows/CVI or repair the existing LabWindows/CVI installation.
Best Regards,
Jonathan N.
(3,947 Views)
That's the reason. Thank you very much!
(3,931 Views)
