LabWindows/CVI
About the 64bit coding
I have read the guide "Porting 32-bit code to 64-bit code" within the cvi 2009's help. As to the specification, e.g., using 'ssize_t' instead of using 'int', I tried to modify the code :
ssize_t authenPanel; //the original define is "int  authenPanel"
SetPanelPos (authenPanel, monitorHeight-445, monitorWidth/6);
then compile it with the X64 option, it gives an error:  "Type error in argument 3 to `InstallCtrlCallback'; found 'pointer to ssize_t function(int,int,int,pointer to void,int,int)' expected 'CtrlCallbackPtr'."
 At the same time, I have got such a warning " Warning: Conversion from 'ssize_t' to 'int' might lose data.", Please give an advise how to avoid such an error.
David
(3,433 Views)
you can continue using int as long as your integer value will not exceed 32 bit, see the discussion here - you do not have to change to ssize_t until you need 64 bit values. Because in the near future panel size probably will not exceed 32 bit valeus this should be ok. Smiley Wink
(3,427 Views)
