LabWindows/CVI
Access to BIOS Real Time Clock using port IO
Hi
I have a PC where one of our vendors sw is messing around with the windows clock. Thus it cannot be used for data stamping etc.
Can i get access to the BIOS RTC from CVI using port IO commands?
Thanks Peter
(4,518 Views)
Hi pkmoller,
Aplolgies for the previous post, I appreciate that you are working in LabWindows and not Labview.
I will look into the matter for you and see what information I can find.
Please let me know if you find anything in the meantime.
Good luck with the application.
Kind regards,
Rob G
(4,491 Views)
