LabWindows/CVI
Accessing GUI in real time
Hi there,
I am in the process of using LabWindows 6.0 to write a program to control a microwave synthesiser via GPIB, which then plots the data in real time.  When the program is running a dos dialog appears on the screen and the GUI can no longer be accessed.  I would appreciate it very much if somebody knows how to get around this problem i.e. how I can change it so that I can access the GUI when the program is plotting data.
Many thanks, Nicholas Fletcher,
University of Sussex
(2,995 Views)
It sounds as if somewhere in your program you are calling the system() function to carry out the DOS based task. This function will wait until the shell has finished before your CVI program (and its GUI) can continue. Try using the LaunchExecutable() function instead - this will allow the main program to continue without waiting for the DOS shell to finish.
JR
(2,993 Views)
Another possibility is that a printf ( ) function has been used somewhere to display debug informations: CVI 6 hase a more confortable DebugPrintf ( ) function that can be used for debug purposes: it is automatically ignored whe the program is executed in compiled version.
(2,988 Views)
