LabWindows/CVI
Accessing Tables on Panels
How do you read / write data to a Table?  Say a 9 row by 3 column table called TABLE_INPUT has been created on a panel.  I have a series of test temperatures and dwell times I'd like to program in a test sequence, and would like to read the array of setpoints from this table rather than use 18 discrete control box inputs.  Seems like the design would be easier to expand that way.
(3,248 Views)
Mike, basically access to a table is performed via SetTableCellxxxxx or GetTableCellxxxxx commands in User interface library. It's not so easy to guide you to the use of this control: table control is powerful but need some time from your side to learn how to use it.
Several resources can be found for this: the online help on tables and some good examples that you can find via Find example... item in help menu are the bases. It is also a good source of explanation and examples the support section of this site: for example, here is the link to the develompent library (a collection of sample programs) for CVI.
(3,244 Views)
Howdy Sandia_Mike,
Refer to the Developer Zone example,
Programmatically Adjusting Table Control Properties for further help.
Best Regards,
Jonathan N.
(3,221 Views)
