LabWindows/CVI
Acquire data from hbm MGC_Plus in CVI
Hi all,
I am using LabWindoes/CVI and want to get measured data from an MGC_Plus measurement amplifiere from hbm. I also want to set up the amplifiere with CVI. HBM publish some ActiveX things for VBA and Microsoft Visual C++ but I don't know how to use these things in CVI.
Best Regards from Germnay,
chemph
(3,155 Views)
Hi chemph,
you can use the LabWindows/CVI ActiveX Controller Wizard to Generate Code. The ActiveX Controller Wizard will generate a new instrument driver for an ActiveX server. This instrument driver contains functions to instantiate the server's object, reference existing server objects, get/set the object's properties, and call the object's methods.
Take a look at the following KnowledgeBase:
"Using the ActiveX Controller Wizard to Generate Code in LabWindows/CVI"
http://digital.ni.com/public.nsf/allkb/4B597F188B89B6DD862568970071F2FC?OpenDocument
Best Regards
Benjamin
(3,146 Views)
