LabWindows/CVI
Acquisition and image processing on reel time
Hello
I am on a project acquisition and image processing using labwindowsCVI and VISION ASSISTANT, I manage to make the acquisition of one  image using vision assistant and then generate the code under labwindows but after for the use in real time mean  with the camera that is moving and aqcuisition images I do not know how it proceeded thanks for your help
ps : I am new to this software
have nice day 🙂
(3,112 Views)
You should be able to import the script into cvi such as it is show in the picture.
For what reason do you need to use an RT OS?
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(3,084 Views)
Hello
what you mean by RT OS
yes i have create project on labwindowsvi but when i want to aquir image by code opencam there are an error i dnt know why
thks
(3,082 Views)
RT OS means Real Time Operating System. You have mentionned it.
Have you modified the code in CVI?
Paolo_P
(3,079 Views)
Ah yep it is ; for code i dont modify  juste i convert the VISION ASISTANT process at code c labwindows after compiling i have error
(3,077 Views)
