LabWindows/CVI
Active-X control not working on 64 bit system
i have a user interface that is using active-x control air.ocx , i have successfully used active-x in labwindows 9.0 on 32 bit system, i have registered that same control on 64 bit windows using regsvr32 air.ocx, i have installed labwindows 9.0 on the 64 bit system , which shows me that active-x is successfully registered , the issue i am facing is this that when i open project on 64 bit system that was build on 32 bit system then it runs fine , but when i make changes to the user interface even changing the position of led and then compile the same project on 64 bit system with labwindows 9.0 istalled then there is a error  " Active-x is not licenced for this operation "   , kindly guide me , i have obtained air.ocx from the 32 bit system on which active-x control was installed and my labwindows project was running fine. thanks in advance.
(4,091 Views)
i have not received any reply yet ,, waiting for this issue to be resolved , i know thirdparty controls are tricky but issue arraises when i am using 64 bit windows and i make a very little change in my project and compile again then issue arrises.
(4,072 Views)
Hi smartprogrammer
Have you seen this forum post? It seems very similar to your own issue, but I will continue to look into this and see what I can find if this forum post doesn't help you!
Andy F.
Applications Engineering
(4,056 Views)
