LabWindows/CVI
ActiveX control
How do I use active X controls on CVI
I would like to display an RTF text on a CVI window, I thought of using
'write' for this purpose but I could not find how to put an activeX
control on a window as it is done in LabVIEW
(5,833 Views)
There is no ActiveX Container in LabWindows/CVI so we cannot use a ActiveX
Control. We do support ActiveX Automation Servers for automating external
applications.
Ori Idan wrote:
>How do I use active X controls on CVI>I would like to display an RTF text
on a CVI window, I thought of using>'write' for this purpose but I could
not find how to put an activeX>control on a window as it is done in LabVIEW>>
(5,833 Views)
Is there any way to do ActiveX container in CVI, using the SDK or something, is
there any examples for this?
> applications.
Ori Idan
O. T. Idan LTD. National Instruments Alliance member in ISRAEL
Email: ori@otidan.co.il
Home page: http://www.actcom.co.il/~otidan
Tel: +972-6-6262353 Fax: +972-6-6262405
Things should be made as simple as possible but not simpler
Albert Einstein
(5,833 Views)
There is no way to do a container in CVI, through SDK or otherwise. We are
working on adding this to a later version of CVI, but it is currently unavailable.
Best Regards,
Chris Matthews
LabWindows/CVI PSE
is>there any examples for this?>>Chris Matthews wrote:>>> There is no ActiveX
Container in LabWindows/CVI so we cannot use a ActiveX>> Control. We do
support ActiveX Automation Servers for automating external>> applications.>>>>
Ori Idan wrote:>> >How do I use active X controls on CVI>I
would like to display an RTF text>> on a CVI window, I thought of using>'write'
for this purpose but I could>> not find how to
a window as it is done in LabVIEW>>>>>>-->Ori Idan>O. T. Idan LTD. National
Instruments Alliance member in ISRAEL>Email: ori@otidan.co.il>Home page:
http://www.actcom.co.il/~otidan>Tel: +972-6-6262353 Fax: +972-6-6262405>++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++>Things
should be made as simple as possible but not simpler>
Albert Einstein>++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++>>
(5,833 Views)
There is a tools (.fp) to display a rtf text. You can find it on NI Web
site.
for more information contact me on email.
Sorry for my english.... I'm french.
Sylvain MICHEL - S.N.C.F.
Agence d'Essai Ferroviaire
21, avenue Salvator Allende
94407 Vitry sur Seine CEDEX
CRT Paris Rive Gauche
Tel 41 94 57 / 01 47 18 84 57
email : sylvain.michel@sncf.fr
--- ce que je dis n'engage que moi, et encore... ---
(5,833 Views)
