LabWindows/CVI
ActiveX controls cannot be created in a thread whose concurrency model is multithread apartment %28MTA%29
Hello There
When i try to load panel with AxtiveX control (any type of activeX) from CVI i get the following error
(return value == -176 [0xffffff50]). ActiveX controls cannot be created in a thread whose concurrency model is multithread apartment (MTA)
Iam using CVI2013 sp1 on winXP
By the way i migrate the code from CVI 2012, on 2012 it worked perfectly
Gabel Daniel
(6,501 Views)
hi application_developper,
This seems like it might be a bug, could you post a simple program that displays this error and I will look into it.
Peter T
(6,444 Views)
Hi
The reproduction of the error is very simple.
Take the sample of UserInt\ActiveX\Webbrowser that is shipped with CVI,
add call to NiScope_Init() before loading the Main sample panel & walla the error is there.
It seems that call to Niscope changes the Thread behavior of  CVI
By the way i tried it with another call to IVI_SCOPE driver from Lecroy with the same result
Gabel Daniel
(6,370 Views)
Hi application_developper,
Thank you for informing me of this behavior, I am going to look into it.
Peter T
(6,306 Views)
Hi applications_developper,
The fix to this issue is to call CA_InitActiveXThreadStyleForCurrentThread prior to calling NiScope_Init.  The explanation of this is that the ActiveX controls need to run with the apartment-threading-model (STA).  When the CVI run-time encounters an ActiveX control it will initialize the thread to STA.  What is happening is that NiScope_Init is probably initializing this to a multi-thread-apartment(MTA) first, so it is running into a conflict when the CVI run-time tries to run it on STA since its already initialized on MTA.
Let me know if that fixes the issue.
Peter T
(6,112 Views)
Thanks for the solution
(6,091 Views)
