LabWindows/CVI
ActiveX error
I used ActiveX to load a PDF reader (Adobe Acrobat 5.0) in LabWindows 6. It works fine in my computer( LabWindows 6 installed). Using Distribution Kit to install the program in other computer, I got the following error:
Error in "LoadPanel (0, "OP.uir", PDF)"
Error code: -143 ActiveX error.
I was trying to reinstall the different version of Adobe Acrobat, but it doesn't work.
Thanks.
(3,400 Views)
Supplementary:
I found that the PDF file open properly if enable the "Register Files as ActiveX Servers"
("Install ActiveX Container Support" is enabled already) during create Distribution Kit.
But problem is : while you click setup.exe for installation, the application program is started automatically before setup.exe done. You have to close the program to let "Setup" finished.
How to solve it ? thanks.
(3,400 Views)
Hello
Are you distributing the ocx file for the Acrobat with your application? If you are, you can try seperating the ocx in a different file group as the exe ( with creating the distribution kit), and then checking the "Register Files as Activex servers" option just for that group. This way, it would only register that ocx and your entire panel wont come up
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,400 Views)
