LabWindows/CVI
Adding Calender Graph
I Have a general question,
I want to create a software that uses 2 dates start date & end date and then show it on a calander something similar to ms Project.....
can any one give some starting tips on what can i use maybe some activex !?
Kobi Kalif
Software Engineer
(3,941 Views)
Kobe,
Have a look at this example and see if it is helpful.
Using the ActiveX Calendar Control in LabWindows/CVI
Peter Rifken - Field Engineer & Business Manager
Boston / North New England & Maine
(3,925 Views)
Hi Peter,
I now see i wasn't clear at my question...
I'm looking for someting like a Ghaant , for seeing process or time related projects...
If you know a good activex it would help.
Thank you.
Kobi Kalif
Software Engineer
(3,916 Views)
I found the following 3rd-party resource which might be useful for you:
http://www.exontrol.com/exgantt.jsp
Found after looking through another post found here:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Gantt-chart-in-labview-or-Java-container/idi-p/1663168
Best,
(3,900 Views)
