LabWindows/CVI
Adding child panels
Is it possible to add 'Panels' within 'Panels' using the UIR editor or programmatically?
(3,066 Views)
The UIR editor does not permit you to create a panel inside an existing panel, you must do it a load time instead. The trick is to pass a valid panel handle in the first parametere of the function; as you ca read in the online help;
parentPanelHandle integer Handle of the panel into which to load the panel as a child panel. Pass 0 to load the panel as a top-level window.
Take a look at \userint\panels.prj for an example on how to create and treat child panels.
(3,064 Views)
