LabWindows/CVI
Advantech USB-5856 with Labwindows
Hello everyone,
I want to use the USB-5856 board for my application "with inductive input sensors and actuators such as pneumatic output valves".
I need to know if Advantech products can work with labwindows? cause i didn't find the driver.
I ask you if you can help me to find a DLL for this card or an instrument driver for I can realize my code under labwindows
cordially,
(3,841 Views)
Any Help plss ?
(3,816 Views)
OuadieAdnan
I found on Advantech's website that the USB 5800 series modules are supported by LabVIEW but not specifically LabWindows, I would contact them to make sure the device is compatible. However, the 5800 series modules are compatible with other C based programming tools such as Visual Studio, so I would not see why there would be an issue with it working with LabWindows.  With regards to the DLL, that would be up to Advantech to supply to you. I would contact them and ask if they have a DLL for your device.
(3,797 Views)
WhiteA thank's dear for your reponse,
actually that's what I found too this map is supported by LabVIEW but not specifically LabWindows. I hope that you will find for me a solution thank you infinitely
(3,789 Views)
OuadieAdnan,
Since the instrument driver is supported by LabVIEW, you can also use this with LabWindows. However, There might not be a specific LabWindows project to build from, you would have to use the Visa functions.
Again, I would contact Advantech because they would have the necessary DLL for you to use with LabWindows.
If you have further questions on how to do this, I would recommend opening a service request  either online or calling 1 (800) 531-5066 and we can assist you further.
(3,785 Views)
WhiteA thank’s Sir you will help me a lot I hope that they have a DLL « driver » so I can use it in LabWindows directly without using VISA.
I’m  kindly waiting for you feedback.
(3,775 Views)
