LabWindows/CVI
Again - XML parser to use with CVI?
I need to parse a XML file using CVI. So I need a parser which will work
with CVI. Most of stuff on web either comes as source code which I have to
compile or works with C++ and JAVA but not C. Tried Oracle XDK for C, but
can't even get their example to work.
I am looking for a simple library or DLL that I can use. I have looked at MS
stuff, can't figure out if it is ActiveX control or what and how to use it.
Any help is much appreciated.
vishi
(3,818 Views)
Found the solution. There is a free activeX control called ChilkatXML. It
uses DOM model, I don't care as my XML files are small. I used CVI's ActiveX
server to FP generation tool (first time) and it is working. Loaded the XML
file and I can read tags, attributes etc.
vishi
"Vishi Anand" wrote in message
news:3e70e419@newsgroups....
MS
it.
> vishi
(3,818 Views)
