LabWindows/CVI
Agilent 33120A: wrong Sine Waveform Amplitude
I have an Agilent 33120A function generator, and I control it with LabVIEW 8.2.1 and CVI 6.0 via GPIB and RS232 interfaces.
I've been using the driver downloaded from NI site but I found a strange problem.
Here the steps to reproduce it (I hope):
  1. power-down the 33120A, then power it up
  2. control the instrument with CVI, and generate for example a sine wave with 300 mVPP amplitude (hp33120a_ConfigureStandardWaveform function with Amplitude input to 0.3)
  3. close CVI communication with instrument
  4. set waveform amplitude to mVRMS with the 33120A fron panel buttons
  5. re-open CVI communication
  6. control the instrument with CVI again, and try to generate a sine wave with 300 mVPP amplitude again (hp33120a_ConfigureStandardWaveform function with Amplitude input to 0.3). A 300 mVRMS sine wave is generated.
After some tests, I found out that you have to set waveform amplitude to mVPP with the 33120A fron panel buttons before controlling it with CVI; otherwise the mVRMS setting is not changed by CVI driver. Or you must power-down then  power-up the function generator, andthis setting isresetted to mVPP (instrument default?)
If you use LabVIEW everything works fine.
If you use a 33220A function generator with the same driver everything works fine.
Is this an expected behaviour, or is this a driver bug?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,895 Views)
Hello vix,
Thanks for the detailed notes, the behavior that you are seeing could be a result of the firmware on your 33120a, have you tried updating to the latest?
D. Beninato
(3,871 Views)
Have you got any update?
D. Beninato
(3,858 Views)
Sorry for the late answer, but for a strange reason my question has been posted into two different threads, and some additional informations are available in the other thread
I suggest you to stay tuned on this one.
Sorry again for the inconvenience
Vix
Using LV from 7
(3,854 Views)
