LabWindows/CVI
Agilent ESG IVI Driver bug
Is there a Frequency Range bug in the latest IVI Agilent ESG series?  If I check the minimum and maximum IVIRFSIGGEN_ATTR_FREQUENCY attributes they report back 100 kHz and 1 GHz, which both are incorrect.  In order to use the driver I had to disable the range checking on the initialization.
Has anyone else seen this?
Thanks.
(3,395 Views)
Hi Blue:
Did you get this IVI driver from NI's Intrument Driver Network?
I'm not sure about this issue but I'm going to look into it.  In the meantime you may want to post to the Instrument Driver forum instead of the CVI forum.
Emilie
(3,369 Views)
Yes, I downloaded the latest to make sure it was still a problem.
(3,352 Views)
