LabWindows/CVI
Always getting "Invalid Argument" error on CNV functions
Hallo,
I'm quite new to LabView/LabWindows/CVI. I'm trying to create a very simple C++ application that will exchange Network Shared Variables with a LabView VI.
But no matter which function I call, I always get the error "Argument is invalid". For example when creating a browser to browse for available variables:
int _tmain(int argc, _TCHAR* argv[])
  CNVBrowser* browser = NULL;
  int retVal = CNVCreateBrowser(browser);
  if(retVal != 0)
    const char* error = CNVGetErrorDescription(retVal);
    std:: cout << error;
  }//end if
  if(browser != NULL) CNVDisposeBrowser(*browser);
  return 0;
 This gives me a return value of -6393 which means "Argument is invalid".
I suppose there is something very basic I'm doing wrong. Can anyone help me out?
Thanks!
(4,244 Views)
I should say that you need to use the function this way:
CNVBrowser browser;
int	error;
error = CNVCreateBrowser (&browser);
The function should correctly return the handle that it creates. While executing your code inside CVI environment you are likely to get a "Null pointer passed to library function" error.
(4,240 Views)
BorisBrock:
You are getting confused over what should be a pointer. The code ought to read something like:
  CNVBrowser browser = NULL;
  int retVal = CNVCreateBrowser(&browser);
  if(retVal != 0)
  if (browser)
    CNVDisposeBrowser(browser);
  return 0;
HTH!
Martin
Certified CVI Developer
(4,239 Views)
Thank's so much!
All those years of C# development must have clouded my pointer-mind 😉
(4,235 Views)
