LabWindows/CVI
An Error "Uninitialized pointer argument to library function" when I use viIn32() Function
I want to use viIn32(*,*,*,val) to get the data(setted to be 0x4) from PXI device. But when I debugged the code, There is An
FATAL RUN-TIME ERROR: "Main.c", line 376, col 40, thread id 0x000000B0: Uninitialized pointer argument to library function.
I right clicked on the variable and select "View Variable Value". I found the value of val is "0x00000100(0) (no size info)".
I want to know what this means and how to sovle this problem.
(4,284 Views)
the function you are using should look something like
status = viIn32 (instrument_handle, VI_A16_SPACE, offset, &value);
value is a pointer of type ViUInt32 and needs to be initialized before you use it in this function call: how did you declare value in your code, and (how) did you initialize it? The error message suggests that you did not initialize it...
(4,283 Views)
Thank you for your reply!
I have solved the problem.
In the old code, I defined the val as ViPUInt32 derectly.
Now, I defined the val as ViUInt32, and used &val in the viIn32() function.
Wolfgang 已写:
(4,280 Views)
