LabWindows/CVI
An internal tool or library returned an error
Installer build error code-21 LabWindowsCVI 12.0.1
[ 신규 ]
While attempting to build an installer I get an error code -21. What is the error and how do I correct it?
// ERROR Message
Adding files to installer
*** Error: An internal tool or library returned an error. (Error code -21)
*** Error Details:
Error in MDF API function: _MDFBuildDevPart_Close
Error in MDF::BuildDeveloperPart::Close.
nmdkAddFile returned error code 26043
*** End Error Report
(4,388 Views)
This error is generated when the distribution builder fails to add a file to the distribution. Typically, error -21 will report which file is causing the error. Since it is not reporting the problematic file, you will have to discover it on your own. Start with the suggestion in this KnowledgeBase article to see if any files show up in red in the Files view. If not, then try removing files one at a time until the distribution builds. If you can locate the problematic file, make sure that it exists at the path specified.
(4,367 Views)
First, thank you for answer.
The problem does not occur on any other PC. OK, so I tried, but the problem is pointed out, the problem was not found.
Thanks.
(4,361 Views)
Could you send me a screenshot of the Files tab in the Edit Installer dialog? Also, do you get this error when building any distribution? Does the error occurr when building an example? How about for an empty template project?
(4,313 Views)
This site is not attached to the image. We will send you an e-mail address and tell.
Thanks.
(4,295 Views)
Hi,  I am encountering this exact error with CVI 2012 as well.  I get the error when building a kit for one of the examples as well.  Was there any solution found?
(4,073 Views)
