LabWindows/CVI
Any other way to create .obj file other than options->Create Object file
I want to create .obj files (not .niobj or .nidobj) for all my .c files in the project.
I dont want to use options->Create Object file, since I have to do this individually for every file.
Please suggest me any alternative.
(3,241 Views)
You have two possibilities:
1. You can write a short app that uses the CVI ActiveX server to load a C file and create object files in a loop. (Check out the examples in samples\activex\cvi. The function you'd need to use is CVI_AppCreateObjectFile)
2. An .niobj file is identical to an .obj file. You can go ahead and create .niobj files and then run some script that renames the suffix and copies them up a level.
Luis
NI
(3,234 Views)
In version 7.1 and higher, you can also use the CVI command-line compiler (compile.exe) to compile a source file into an object file. The CVI command-line compiler is installed in the CVI installation folder (same folder as cvi.exe).
(3,214 Views)
