LabWindows/CVI
Any way to draw lines at design time on CVI UIR file
I know I can use canvas control to draw line but that is within the code. Is
there way to draw lines when designing the UIR?
Or any line ActiveX controls that I can use?
vishi
(2,951 Views)
You can use the canvas control and import a bitmap that has a line at the design time. Also, you can use a decoration control, and make the height very small, then change its color to whatever you desire to make it look like a line.
Mika Fukuchi
Application Engineer
(2,951 Views)
