LabWindows/CVI
Anyone has experience with locking certain functionality of your app?
I am developing an app in CVI where I would not want my users to have
certain functionality unless they have paid for it or authrorized to do so.
Maybe they send some specific information about their machine and then I
give them some code and the application only runs on that machine.
Any ideas? I am not looking for solutions like where I write something to
registry etc. I am looking for way to implement licensing policy. Willing to
pay for third party solutions which can integrate easily with CVI.
vishi
(3,106 Views)
There are quite a few licensing packages that vary from simple to very sophisticated (and vary from inexpensive to way expensive). Most create a "wrapper" around your app and then can allow access to certain areas depending on your desire. Many allow you to make simple changes in your code to change this functionality.
I looked into Flexlm for a software app my company produced, but found it to be too expensive for us. But it is extremely versatile if you can afford it. They also take care of the licensing from a central office. So you don't have to deal with customers calling you for authorization codes... They do it through the licensing software company.
We ended up doing our own authentication based on information from the specific computer that
the app was loaded on (i.e. Windows reg key, serial numbers, ...) and creating our own simple algorithm to come up with an authorization key. At startup, if the auth key is not already there, the user is given a Registration Key which they need to call us with to get their specific authorization key. And the algorithm and authorization key system we devised allows us to determine which funtionality, and therefore dll's, they are allowed to use. So if we want to restrict them from using some functionality, the dll will not load if the auth key shows that they are not permitted. This has worked well for us in this instance.
Other than the big-name licensing software companies, there are a number of shareware licensing solutions, as well. You will need to do the research yourself because there are so many products, and each offers different functionality which you may or may not want for your specific case.
Do a search under "licensing control software" and a bunch of things w
ill pop up. Or go to shareware.com and search around. I think there are a few that will come up there.
Good luck.
(3,106 Views)
Thanks Craig.
I am also looking at creating an authorization key based on some unique
information of the particular computer.
vishi
"Craig Leidholm" wrote in message
news:50650000000500000019DF0000-1042324653000@exchange.ni.com...
> company.
> specific computer that the app was loaded on (i.e. Windows reg key,
> specific case.
> will pop up. Or go to shareware.com and search around. I think there
> Good luck.
(3,106 Views)
