LabWindows/CVI
Anyone used Canberra CSP library in LabWindows/CVI ?
Have trouble to communicate with CSP library.
George Zou
(4,172 Views)
What kind of trouble are you having communicating with this library? I'm not specifically familiar with the Canberra CSP library, but perhaps I could help you troubleshoot from a CVI perspective.
-Will
(4,150 Views)
Thanks for reply.
No problem when compile / link.
CSP dll returns error when use.
If I call CSP Open, then I got error indicates hardware is not plugin.  But this is not true, since Canberra application can connect to the probe without problem;
if I don't call CSP Open (not called in Canberra c++ example, but is called in .net example), then sequential calls get error indicates wrong function used.
George Zou
(4,147 Views)
Have you used this DLL in other development environments?
(4,129 Views)
LabVIEW and CVI.
George Zou
(4,084 Views)
George,
I'm sorry, but I've not been able to find any information on this library that you are referring to. However, since the error is casued by the call to CSP Open, Canberra (or whoever created this library) may have more information for you. The problem does not appear to be related to CVI from what I've gathered so far.
-Will
(4,069 Views)
