LabWindows/CVI
Anyway to change the speaker volume when using StartPCSound?
I'm using StartPCSound() from Programmer's Toolbox, it does work but the result is quite loud and I didn't find anyway to reduce the volume.
No way by code, no way by Volume Control of Windows.
Anybody can help me?
Sergio
(3,670 Views)
Hello Laser,
hope this helps:
#include <mmsystem.h>
/* Get volume
int CVI_waveOutGetVolume (void)
unsigned int result;
unsigned int volume;
result = waveOutGetVolume (
0, //HWAVEOUT hwo, // First (and only) audio device
&volume //DWORD dwVolume
volume &= 0xFFFF; // Extract left value only
return volume;
/* Set volume
void CVI_waveOutSetVolume (unsigned int volume)
unsigned int level;
// Level for both channels (high byte ignored of monophone)
level = volume * 0x10000 + volume;
// Set volume
result = waveOutSetVolume (
0, //HWAVEOUT hwo,
level //DWORD dwVolume
sprintf(temp_str,"Volume: 0x%04X", volume);
WriteToLogfile("CVI_waveOutSetVolume", temp_str);
Greetings from Bremerhaven, Germany
Norbert Rieper
"Laser" <x@no.email> schrieb im Newsbeitrag
news:1190194814309-582454@exchange.ni.com...
> Hi, I'm using StartPCSound() from Programmer's Toolbox, it does work but
> the result is quite loud and I didn't find anyway to reduce the volume.No
> way by code, no way by Volume Control of Windows.Anybody can help
> me?ThanksSergio
(3,660 Views)
StartPCSound and StopPCSound work by manipulating the registers of the sound chip on the motherboard. I don't think there is a way to control the volume in this case. You should use the PlaySound or sndPlaySound Windows SDK function instead. See samples/sdk/audio. With this function, Norbert's code above should also be able to control the volume - or you can set the volume in the Windows Volume control panel.
(3,656 Views)
Norbert's code works, but only if I use SDK functions such as sndPlaySound, as suggested by Mohan.
So I'll manage to replace StartPCSound with SDK functions and wave files in my code.
Thank you All
Sergio
(3,626 Views)
