LabWindows/CVI
Arbitrary waveform using hp33120a driver in labwindows/cvi
I am using labwindows/cvi.
I had downloaded the hp33120a driver for agilent 33250a/33220a function generator.
I am facing the problem, how to create the arbitrary waveform?
thanks & regards,
vikrant
(4,437 Views)
Hi Vikrant,
What problem are you exactly facing?  Do you receive an error notification or an incorrect output?
Vaibhav.
(4,406 Views)
Hi Vaibhav,
                Sorry for delayed reply as i was out of station.
                I do not know how to create the arbitrary waveform .
I had array of points with values between -1 to +1.
Which of the functions to be used?
thanks & regards,
vikrant
(4,363 Views)
Are you using the IVI driver ?
If you want to use the interchangeability of the IVI driver, you should use the IviFgen class driver, and call the following functions :
IviFgen_ConfigureOutputMode (IviHandle, IVIFGEN_VAL_OUTPUT_ARB); // select to generate an arbitrary waveform
IviFgen_CreateArbWaveform (IviHandle, nbEch, arbWaveform, &arbWaveformHandle); // create the arbitrary waveform where arbWaveform is your array of points (and nbEch the number of points of the array)
IviFgen_ConfigureArbWaveform (IviHandle, "CHANNEL1", arbWaveformHandle, gain, dcOffset); // configure the attibutes of the arbitrary waveform
// You have an array with values from -1 to 1. To configure the output signal to range from -2.00 volts to +2.00 volts, set the gain to 2.00.
IviFgen_ConfigureSampleRate (IviHandle, sampleRate); // determines the rate at which the function generator produces arbitrary waveforms. (samples per second)
IviFgen_ConfigureOperationMode (IviHandle, "CHANNEL1", IVIFGEN_VAL_OPERATE_CONTINUOUS); // select to generate output continuously
IviFgen_InitiateGeneration (IviHandle);// moves the function generator to the Output Generation State.
IviFgen_ConfigureOutputEnabled (IviHandle, "CHANNEL1", VI_TRUE); // the signal the function generator produces appears at the channel's output connector.
If you want tu use directly the specific driver, replace the "IviFgen_" prefix by the "hp33120a_" prefix (for function names and constants).
Hope this will help you.
Bruno
(4,353 Views)
Hi Bruno,
             Thanks alot.
I am busy these days doing some other activities. I shall let you know when i shall check it.
I am not using IVI driver.
thanks & regards,
vikrant
(4,332 Views)
