LabWindows/CVI
Arduino as Ethernet Server - Simple ModBus
Group,
I have an Arduino with the Ethernet shield communicating with LWCVI via the standard TCP/IP library.  I will eventually create a small ModBus (TCP) implementation with this system to retrieve analog data and send commands to the Arduino.  If you are interested in this technology, drop me a reply and I will post code/examples/etc.  Suggestions welcomed.
Thanks, David Eaton
(6,881 Views)
i am interested. I am trying ot figure out how to do this now.  using a Arduino as my data aquisition device and able to connect to it and see the data in my labview promgram on a pc over ethernet.
any info is appreciated.
chuck
(5,079 Views)
Could you show me a working example. Which libraries to use on Arduino side, etc.
(3,955 Views)
Hello Layosh, the OP did not connect on the forums since 2015: I don't suppose you can get any reply from him.
(3,950 Views)
I did not pay attention to that, in fact I was absent for a while, programming was not the priority of my tasks. But it is changing again, 🙂
I was playing with networking a bit, but microcontrollers, instrumentation and secure logging  are the new target.
(3,940 Views)
