LabWindows/CVI
Are there any performance profile tools for CVI?
I'd like to profile my code to look at memory usage. I have an error checking macro that passes the function name to an error handler, but I'm concerned about the number of static strings this is going to create in my code. Anyone know how to analyze this? Or, is there is a better way to pass the function name to my error handler?
(3,368 Views)
Hello Mark,
NI does not make a profiling tool for LabWindows/CVI, nor do I know of any third-party ones (a third-party one is unlikely as CVI does not provide an interface for third-party plug-ins or add-on products). However, to help in tracking down memory leaks on the heap, the function CVIDynamicMemoryInfo() can be used. It will give all information CVI has regarding memory allocated/deallocated by new/delete.
Regarding your static string situation, your program/memory footprint size should only increase by the total length of all static strings in your program (including the NULL character) plus the code to perform the error checking. The code that is inserted to perform the error checking (and call the proper error functions in the true case) is blin
dly inserted (#define) in every case, and they will likely be larger than the size of your static strings. Is the total size of all of your function names really large enough to be of concern? One note is that __FILE__ will cause a new static string for each time your macros are inserted (the compiler does not go through the list of static strings to search for redundancies). As such, you might want to define one static string for each of your files (myfilename = __FILE__) and use it in your macro to gain some memory savings. If you are really worried about memory usage, you could assign a number to each function and use a mapping of some sort, but this would likely result in a minor memory savings for a major pain when debugging an error (the cost/benefit is thumbs down). I would recommend tinkering with your error macro considering the above information then watch the size of executable created (since you are observing static objects, the executable size will be a direct correla
tion). I hope this information is helpful to you.
Jeremiah Cox
http://www.ni.com/ask
(3,368 Views)
Two additions to my response:
1) An compiler that performs optimization WILL usually reduce redundant static strings.
2) You could compile your code in another compiler (MSVC for example) and use the CVI libraries/objects. This would allow you to use both their optimization and profiling tools. Please see http://zone.ni.com > Developer Zone > Development Library > Measurement and Automation Software > Measurement Studio > LabWindows/CVI > Advanced Programming Techniques > Building DLLs > "How to Integrate 32-Bit LabWindows/CVI 4.0 Libraries into Microsoft Visual C/C++ or Borland C/C++" or see the CVI documentation > Programmer Reference > Compiler/Linker Issues > "Using LabWindows/CVI Libraries in External Compilers".
(3,368 Views)
Thanks Jeremiah
I think this is the best alternative, And I will give it a try. I am not so worried about memory leaks as much as identifing how much time is spent in each routine and how often they are called. In our testing improving the test time can bring big benifits over a years worth of production. With our UNIX tools we have used this to improve our software designs and system partitioning....
-roman
(3,368 Views)
