LabWindows/CVI
Ascii codes
I want to know how program the ascii codes of a string to send them by the serial port, using labWindows/cvi plantform.
(3,534 Views)
Please see the sample program "serial.prj" for serial communication we deliver with CVI and which you can find under \programs\National Instruments\MeasurementStudio\CVI\samples\rs232.
Heinrich Illig
(3,534 Views)
What I really want is how to program the ascii codes of a string. Thank you very much for your answer
(3,534 Views)
ComWrt() writes a string directly. You don't need to know the ASCII codes and your program doesn't need to convert the string to an array of ASCII codes.
/*------------------ Prototype -------------------*/
int ComWrt (int COM_Port, char Buffer[], int Count);
For example, to write all of myString to COM1:
bytesWritten = CmWrt (1, myString, strlen(myString));
(3,534 Views)
