LabWindows/CVI
Async timers
When I click a button, I create a timer like:
Timer_Id = NewAsyncTimer(0.1, -1, 0, TimerFunc, 0);
Now in TimerFunc, I use EventData1 param which is
if (Event == EVENT_TIMER_TICK) {
if ((double*)EventData1)
currentTime = *((double*)EventData1);
From help, eventData1 is a pointer to a double that represents the current
time in seconds and is relative to the start of the first timer event.
After some time, I destroy my timer with
DiscardAsyncTimer (Timer_id);
Problem is when I click the button again and create a new timer. The
EventData1 param keeps showing time from the very first timer that was
created, not when button was clicked. I am assuming the by creating a new
timer each time the button is clicked, EventData1 shall show me time from
that in
stant.
vishi
(3,230 Views)
Hello
The eventData1 is supposed to return the time from the very first call, not since the last time the timer was created. To achive the effect you require, you might need to keep track of it yourself with a global that you initialize and that keeps track of the number of callbacks that occured
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,230 Views)
