LabWindows/CVI
At compilation I get a Missing prototype error.
I have a compilation problem.
static CAObjHandle CalendarHandle;
BCGDATETIMELib_Active_DBCGDateTime (NULL, 1, LOCALE_NEUTRAL,0, &CalendarHandle);
ERROR:Missing prototype
Please help me.
(3,498 Views)
This sounds simple although I can't find a quick answer at the BCGDATE website.
It sounds like you need to #include a .h file from BCGDATE with your function defined. Check to make sure you have the correct case, spelling, and spacing.
(3,498 Views)
In addition to including a header (.h) file from BCGDATETIME, you may also need to add a library (.lib) file to your project. This library file will resolve any linker errors that you may run into when building the application.
Jeremy L.
Jeremy L.
(3,498 Views)
